Metalhead47
Couldn't find anything specific in the search. I've got a 2wd POS 'burb that I'm pulling the 6.2l from to put in my 4wd gasser. Got the front end of the donor truck pretty well stripped down (no front clip). I was planning on pulling the engine & tranny (700r4) as a unit (since it was a nightmare to separate the two when I pulled the engine on my 4wd). Now that I can see that humongous 2wd crossmember I'm not so sure. IS it possible to lift the engine enough to clear the oil pan over the crossmember with tranny attached without crushing the top against the firewall?
