Quick Question...
Chevy305
6 Lug 14bsf Status
New Hampshire
So does any one's t-case shifter light up? Like a running light that come on with the headlights. Its on the floor right next to shifter that should light up the shifter pattern. I think its just 208 or 241 that might have that...
Yes, IIRC mine does or did. There is a light inside the plastic housing as you've said. I have an 89 with the 241 T-case.
sweet thanks :waytogo:
I've been trying to figure it out since i found a nice hole for a light bulb to fit into on the underside of the plastic boot thingy.
Where can I find a light socket like the one that fits in there?
Easiest place..
Junkyard--in another truck like yours!..:D
Or perhaps you can swipe one from an aftermarket gauge--I assume your looking for a socket for a bulb like an 1816 ,that has prongs all around the outer edge that clip into a hole (looks like a flower!)..A good parts store might have them,like NAPA,too..(I have some in my junkpile stashed away)..but the junkyard is the place to get the right one--nothing will fit better than a factory one designed to go there..:crazy:
Im going to the junkyard tomorrow to look at some stuff. I know of a few blazers and suburbans there ... if you want I can snag you one and mail it to you ... that is if you dont want to get one up there
If you find one pull it and pm me. I do plan on going back to my local yard on tuesday next week, but most of the trucks are pretty well stripped. So we'll see...
My 83 with a 208 does, didnt know it till i pulled up the carpet and found the wires
