Quick, spring question!!! Need to buy
you guys are confusing me. lol. ok lets start over. blazers should have 52" springs stock. suburban's could have had either. most 3/4 ton trucks should have 56". most 1/2 ton's should have 52", although i have seen some with 52".
when measuring lift springs they should be longer then stock size if you measure along the arc, since there is lift.
when you measure eye to eye with weight on them, they will be longer, cause the weight spreads them out.
i know when you have both sizes laying on the ground, with no weight, there is a distinct difference. i think that goes out the window with any weight and lift.
