quick yes or no guestion
K5-newf
canada
Can you got a 3/4 6 lug 2wd?? i just figured they were half ton or heavey halfs. And if so what would it require to do swap the front end.
Yes, 6 lug 3/4 aren't really that rare.
Do you mean how much work is it to swap a solid front axle under a 2WD truck? Just buy a 4WD, its not like old Chevy's are expensive.
i meant can you get spindles/hubs in 6 lug for a 2wd drive truck
boz42 said:
depends on the truck 67-69 1/2 ton 2wd were 6 lug from the factory.
Actually, 67-70 1/2 ton 2WD trucks were all 6 lug, 67-70 3/4 ton 2WD trucks came either 6 or 8 lug. These were all 4 wheel drum brake though. Starting in 1971 GM used 5 lug on the 1/2 ton with disc brakes and 8 lug on the 3/4 ton trucks with disc brakes.
