I'm finally tired of sweltering. Adding freon every spring is not working anymore. The last time I added, using gauges, the low side was up to 70psi and the high side was lower than it needed to be. The diagnostic info I read said that was a pretty good sign that there's at least one bad reed valve in the compressor.
So, I'm starting to research what parts to get to convert over to a sanden compressor. So, hey, what better place to start than with my buds here on CK? I have looked at some of the posts and haven't really found info for my specific application.
I'm hoping someone here has done this exact swap and has info on what brackets, compressor, and condenser to get, and who to get them from.
Here it is:
88K5
350 TBI (stock)
Drivers' side r4 compressor (currently), already converted to R134a by p.o.
Single Vbelt driving it.
For reference, here's a visual:
Here it is:
88K5
350 TBI (stock)
) All I can hear is a small click when the clutch engages. If it wasn't for the slight RPM drop, and the (small but noticeable) loss of power on my POS 305, I wouldn't even be able to tell it was engaged.
