Radiator Support Dual / Single Headlights
movario
Registered Member
Switzerland
Hi
I need a new radiator support. Im almost 99% sure, but I would like if someone could confirm as sometimes the trucks in europe get butchered to fit euro certified headlights.
This is a single headlight front, right?
1 headlight per side = single light . combo low & high beam in a 5" x7" size glass
2 headlight per side = 2 headlight the upper is low & high and lower is a extra high only and 4" x 6" size
what are they doing to them to butcher them ? i know we over here can get aftermarket led conversion bulbs from GOOD name brand makers not import cheepy stuff . and they ask us left or right hand drive for the bulb lens to be compliant with the rules and driver needs . i know over there they love ( and i do also ) the amber rear turn and not using red for all of it .
So the one in the picture would be a single headlight radiator support?
Because I guess the lower lights are just turn signals (can't check because everything is disassembled).
Every modification to make it road legal is different and mostly diy stuff. So it's sometimes hard to track all the modifications.
Most countries in the EU require US cars to have amber turn signals. But the one i'm living in does not, so I'll change everything back to stock.
