Actually, Copper has a much higher heat conductivity than aluminum does; 400 W/mK versus 255 W/mK. Aluminum conducts less than 65% of the heat that copper does. The reason most rads are now aluminum is simply due to cost. When I replaced the rad in my k5 last year, I bought a spectra premium brass/copper rad. It was about $100 more than an aluminum/plastic rad, but well worth it imo. I looked into rebuilding the factory rad, but there was not much difference in price, and the tanks on mine were kind of beat up.
Conductivity is not what a radiator needs, it's heat dissipation, and that is what aluminum does better. That is why most if not all heat sinks are aluminum.
That is why aluminum radiators cool better with less rows.
Actually if you could make a single row you could get better heat dissipation per CI because the hot air doesn't hit the second layer.
That is why 4 row radiators do not cool 25% better than a 3 row.
Copper has one advantage though, it's easily repairable with common tools, aluminum and plastic not so easy, and not everything is repairable.
I have repaired a copper radiator that was smashed in an accident, even the tanks were messed up and I took it appart, straightened the tanks, welded the broken parts, and then sealed the few parts of the core that busted open and I had a decent radiator to get me home.
Can't do that with a plastic/ aluminum radiator.
