So, as some may remember my '78 Blazer is lifted at 4" and has a 203 with part-time kit with warn manual locking hubs and the 203 is dropped, done by a previous owner.
I want to get the 203 or 205 for that matter back up to the stock location and in doing so, I have ORD competition motor mounts I want to install and will need my exhaust redone. It drops a tad too low to do this presently, lift Tcase while keeping existing exhaust. I have electric fans so the shroud isn't an issue in any of this. If the exhaust wasn't in the way I'd just lift the 203 back up and see if it vibrates if it doesn't then I'd just send it. I'm more inclined to just leave the 203 for now as I would hopefully not have to get new drive shafts or have mine redone just yet.
I also have a 205 I can put in or I can leave the 203 in until it dies and just get it back to stock location until its death. I'm fine to do this as the 203 seems to be fine.
So what is the best coarse of action here? Steps to be taken in proper order so I'm it redoing stuff pointlessly?
Have exhaust redone first to have it up in the frame rails? Or remove the the exhaust from the header collector back and do the 203 lift and motor mounts? And Just drive it to exhaust shop with open headers?
Or just go for it and put the 205 in now
I want to do plan this out so I'm not redoing things in the process.
I will probably wait until after the AZ summer to tackle this, well maybe I may get restless and just start.
