how does this look? also there seems to be some things not smooth... guess i can carefully sand them off???
69 or 75 $ here
http://www.dbelectrical.com/c-3381-winch-motors.aspx
sorry i posted this before i niticed the above post
Best bet is going to be a starter shop. Most all starters use the same basic type bolt. Solid copper with a square head with a slot cut in it.
Never actually replaced one myself. I've got access to a great starter shop, so I don't have to.
Just from looking, I would say that the wires lay in the groove, maybe are crimped slightly, and then soldered.
You might find one in a good electrical house, or something you can use. Some very good hardware stores might have one, probably not Lowes or HD.
If you strike out completely, let me know by tomorrow afternoon, and I will swing by the starter shop and see if I can't pick you one up on the way home.
There may be more than one size. Make a guess or measure the diameter if you can. Its got to fit the insulator fairly closely.
If you don't know for sure by tomorrow afternoon, thats OK, but I won't be going by the shop for sure again before Monday.
There is an old winch motor out in the shop that was so bad off that even I could not salvage it economically.
Its laying there somewhere in pieces. If I spot it in the morning on the way to work, I'll see what it would take to get a post out of it.
you ever take a look for it???
