Ok, so I"m putting together my last main parts order for my K5. I'll be getting a RamJet350 engine. I've been investigating headers for the engine. The RamJet manual states:
The trouble is, headers for a SBC with 1-3/4" primaries seems far and few between, and the ones that are out there are very pricey are not particularly made for our trucks, so there may be clearance issues. Is it completely necessary to have the 1-3/4 primaries? I'm not an engine designer, but I wonder, what would the effects potentially be if I went with much more readily available 1-5/8" primaries?
Any recommendations? I do want a header with a good thermal coating, and I don't mind paying for it. I was leaning towards the Jet-hot coating, but some of the ceramics, so long as they hold up, might do good too.
RamJet350 Manual/GM Engineers said:Headers:
A RAMJET 350 engine should be equipped with a header exhaust system for maximum performance in applications where a non-production exhaust system is legal. All of the calibration development work was done with a header exhaust system installed on our development engines. Installing production style exhaust manifold may increase backpressure and alter the performance of the system. The recommended
header configuration is 1-3/4" diameter primary pipes, 32 to 36 inches long, with 3" diameter collectors. Use 2-1/2" diameter tailpipes with a balance tube ("H" pipe) and low restriction mufflers.
I think it's time for you to go pound sand.
