dbreid
All,
I have a set of Rancho Add-a-Leafs I used in the rear of my Suburban for a few years. They added about 2 inches (just the leaves alone added into the stock spring pack) and with Zero Rates, I was easily able to clear 37" tires on this setup.
I removed the leaves (which also add spring rate, for increased carrying... they aren't overloads) when I went with a shackle flip because it was too tall, and now I am hoping someone else can use them.
This is just for two leaves. No pins (who would use used spring pins anyway) or anything else. This is all you need. Just two bent pieces of metal.
Here's the listing on Summit:
http://www.summitracing.com/parts/RAN-RS50212/
Part number is: RAN-RS50212
You can read up about them on Rancho's website. They worked well for me, and are 75.18 before shipping new, so I figure 25.00 plus whatever shipping is (which might well not be cheap as they are too long to go in a flatrate box...).
If you are local to the SF Bay Area, CA, you can pick them up, or I can meet you some place.
-Dan
-Dan
