Raptor Liner
Iirc, there’s a collapsible rod that goes between the bracket and your seat. When the seat is folded forward the rod holds it in place, release the lock and the seat goes back to its usable position.
Ok thank you! I will keep it!
Anyone have any ideas on how to fill or seal holes that go completely through the back floor of the Blazer? I thought to just bondo over it but then I leave the hole exposed on the other side.
I did the entire undercarriage on my blazer when I finished floors. I prepped with 80grit and acetone. Then I sprayed upol acid etch on and mixed upol and sprayed. I ended up putting 2 to 3 coats on depending on certain areas. It will take a grinder to pull that stuff off now. 4B2892CD-C5AF-4DE5-9E8D-DB25E9A8A801.jpegBDFF0BB2-8BBD-4EE6-8DDB-DC63133F7175.jpeg
I did the entire undercarriage on my blazer when I finished floors. I prepped with 80grit and acetone. Then I sprayed upol acid etch on and mixed upol and sprayed. I ended up putting 2 to 3 coats on depending on certain areas. It will take a grinder to pull that stuff off now. View attachment 319324View attachment 319325
Damn that's on another whole level. I don't have the resources for that. Damn it's nice!
Can you get a better picture of one?
Looks custom, normally there is a trim piece for the carpet and only sheetmetal screws.
Thank you for the response. I will get a better picture. No idea what they could be for?
Do you think acetone will remove that black residue from those black pads? I think they were for sound deadening.
Ever finish this project? Curious how the raptor turned out?
It's on hold. Unfortunately I have no workshop. Being that it's winter there is no possible way unless I pay a shop. Everything is on hold but I will update as I go along. Thanks for checking back!
