Back in 2013 I installed my ORD Alcan front springs and shackles. After originally wanting to go with 3" springs, I decided to go with 4" for ease of crossover steering and the extra travel for a smoother ride. I strategically ordered 4" springs to use with 33" tires so I could fit in a normal garage with no issues. Worst case I would have to air down a little bit.
I was told way back when I was complaining after installing the springs, stock top of axle tube to bottom of bump plate for a stock height truck is 8.5" to 9". My truck sits at 14". So I have 5.5" - 5" of lift on the front. I am running DIY4X rear shackle flip.
To this day (several k miles and 4 years later) I am still really frustrated with the springs. They are NOT 4", they NEVER settled to 4". So now I have to air down until almost fully flat tires with my undersized 31" tires to even think about getting in the garage. The springs ride great in a straight line or offroad but the truck is nearly undriveable without a sway bar at highway speed. I kind of got used to it, my wife still freaks out about riding in it. I knew it wouldn't be the best at high speed going in, but they surprised me. I swear I can feel the axle get sucked sideways when I hit a puddle driving down the road! Maybe the EZ rides are what I need? Re-arching the ORD Alcans will probably be outrageously expensive? I have already spent a ton on the springs and had been unhappy since the beginning. I just kept hoping they would get settled in.
I am currently re-doing my transmission which requires rewiring the LS harness. So I am going to take this time to re-build it into exactly what I want. The wife and I pretty much only use the truck for camping, light trails, "overland" style stuff, and hope to make some pretty long distance BDR trips.
Current Setup:
Things I am considering changing:
Current Setup:
- Carshop Inc setback plates for motor mounts
- Rubber Motor and Trans mounts
- Stock Crossmember
- Engine mounts - DIY4X, ORD?
- Engine crossmemeber - LS engine setup, which crossmemeber for no clearance issues with motor and crossover steering
- All poly trans mounts so I hopefully stop shearing off the bolt on the bell housing which holds the NP208 T-case support rod
- Figure out front springs
- Finally FIX AC - Mount setup? DIY4X or ORD allow use of stock LS location AC setup?
- Adding Front receiver winch mount for a removable winch. - Shouldn't drop the front much. Had someone sit on the front bumper and the truck drops less than 1/4" with their additional weight.
