Every one that I have, or have driven has ORD shackles. I did the shackle upgrade before getting rid of the Tuff Country springs on my '70.I'm, curious if any one using the ORD springs and complaining about lateral spring movement, installed the upgraded ORD rear spring shackles. I have to agree with K5Wrench. Leaf springs are made to flex up and down, not side to side.
Are you referring to the FUSH kit? If so, yes I have that on mine. As @campfire said, removing the sway bar alone is enough to give you completely different feeling on the street. The side to side push/pull of crossover steering on top of that, plus the ORD (Alcan) springs, just magnifies that.I'm, curious if any one using the ORD springs and complaining about lateral spring movement, installed the upgraded ORD rear spring shackles. I have to agree with K5Wrench. Leaf springs are made to flex up and down, not side to side.
I really don't remember who it was, but I believe it was ORD who listed the height. I looked through the old original service manuals and wasn't able to find the info. On newer trucks that is an actual spec to be measured.@metalneverdies who got you the measurement for a stock height truck? Did they have a known, factory perfect truck, with no miles on it, to measure?
I am just saying that their measurements can be off, and ORD may be off less than you think. Just a thought.
What if you buy a different set of springs and get similar height, but get a stiff ride?
It's a nice looking rust free truck. I'm the second owner and wanted to keep it nice looking. Plus if it's in the garage I don't need to worry about wrenching on it. It's also a requirement for the insurance I have on the truck.Take the sway bar out of the equation and the K5 is an entirely different animal.
To quote Kate Bush;
What made is special, made it dangerous.
She was talking about a glow in the dark yo yo.
But Chevy K5's already have a flexy suspension stock.
Just unbolt the swaybar and make sure to put some longer brakelines up front.
I wheeled an 84 K5 at stock height for years in Hollister hills until that damn Oak tree murdered it.
I think what the OP is experiencing is normal.
I drove home a few times without bothering to reconnect the 1 1/8" bolts and even at stock height.. it was sketchy.
Add a lift and soft spring rate..
But the Tuff Countries I have are just an inch lower than the OP.
Look at the pictures.
But with my sway bar connected it rides even better than the sacked out stock springs i replaced.
Some of that is new bushings.
Some new shocks, rear shackle flip too.
I think the sway bar or rather; articulation limiting bar, is the biggest factor at work here.
He wants the offroad prowess AND a satisfactory road experience.
In this case, to me, reading his posts I think he'd be happier with stiffer springs like I have, or remove the cross over steering that is preventing him from running the stock swaybar/correction disconnect.
I dig having it both ways.
Sometimes I have to move trailers for the lodge.
Having that swaybar rocks.
Pull two pins and I am back in party mode.
No, I am not going to the RTI ramp championships.
But I have a compromise geared right between that suits my needs.
What baffles me about the first post in this entire thread is the surprise that it would not fit into the garage.
Who puts an articulation lift on a K5 and worries about garaging it?
No hate here.
Just found that to be an odd disparity.
Ok, well I had no clue, so I guess that I am not any help.I really don't remember who it was, but I believe it was ORD who listed the height. I looked through the old original service manuals and wasn't able to find the info. On newer trucks that is an actual spec to be measured.
