Re:steering arm
tommysblazer10
new jersey
Install my 4" lift and having a hard time getting the stock steering arm off got the 3 nuts loose put it wont come out anyone has dealt with this ?? Any help appreciated
Take a small sledge hammer (2-3 lb) and start smacking the hell out of the arm. There are 3 cone washers below the nuts that keep the steering arm in place. You must smack the arm around enought to get the washers to unseat themselves and pull them out.
It can be a huge pain in the ass to do if there is alot of rust on there. Just starts swinging on the arm like you want it to die a horrible death and hope for the best. Hit the arm from both sides to help try and break it all free.
The best places to hit were the GM part number is cast into it and where the draglink end hole is at.
If none of this works get a bigger hammer.
Harley
It really is excellent therapy. One of the guys around here had to put the weight of the truck on the arm to get it to unseat. Had to let it sit overnight to get it to let go. I think he used a 2x4 or somethin wedged between the ground and the arm.
I just did the smack the bejeezus out of it method. I've heard I got lucky it only took about 5 minutes.
[ QUOTE ]
Usually here in the rust belt we have to remove the axle and beat it with a 20 pound sledge.
[/ QUOTE ]
yep done that numerous times. its a pain that way though. get to do it tomorrow /forums/images/graemlins/1zhelp.gif
[ QUOTE ]
[/ QUOTE ]
I've found it to be easier to leave it in the truck... /forums/images/graemlins/confused.gif
[ QUOTE ]
[ QUOTE ]
[/ QUOTE ]
[/ QUOTE ]
I have found no easy way to beat it with the body in the way.
I have an air hammer now and I'd probably use that if I had to do another one.
The guys at Dana were so nice when they put that spring there that pulls the arm for you on the '60. /forums/images/graemlins/rotfl.gif
I had to use the large sledge on the last one I separated and ended up bending two of the studs - what fun it is to try to remove the studs to replace them.
