rear brake caliper position
down4thakrown
flagstaff,az
were about to put my buddys 14blt in with disck. but when we mounted the caliper bracket at the 11 o'clock postion instead of the 1 o'clock position. like so the caliper is in front of the axle instead of being in the back.....
I don't think it should matter other than aesthetics . Just make sure the bleeder is mounted up or it will be a mother to get all the air out. I think you would just switch sides with the calipers.
