rear brakes lock up...help!
PsychoticDeadGuy
Fairfield, California
I just finished my 14bff swap, or so i thought. i took it down the street and it drove great...until i pressed the brakes...the passenger side locked up on the 14bff. is it just because of the larger brakes or what? i am running 33s on it front & rear. whats the deal? whay doest the driverside lock up? should i replace the drums and shoes? or what? thanks
could be a leaky wheel seal or cylinder. The pads get saturated with oil/fluid and it creates an instant grab with the slightest touch of the brake. Or if its got a gov loc you may have a problem with that.
Check for wet shoes. If so, fix leak and replace with new shoes.
the side that did have the seal leek doesnt lock up...its the clean side that does...i got the dirty side almost near clean. i dont have the money to spend on those 1 ton brakes right now...it is an open diff i believe...
Looks like around $25 to $35 for the riveted Wearevers. Make sure to take the old ones with you for the core and to make sure you get the right ones.
I think $12 for the kit.
some trucks just do this, you have to remember that rears of empty trucks are light, and the big brakes in the FF's make it easy for this to happen, ive seen it happen alot,
from my own personal experience, leaking brake fluid on shoes will cause lockup.. and very, very easily
or they could be metal to metal, which ive seen happen also
or the truck has great brakes and is just too light in the rear, or the prop combo valve may be faulty and letting too much fluid to the rear
thats always possible too,
stuff is old, has wear
I have had a few things cause the lockup. soaked pads of course, air in the t valve let one side work and not the other and a brake hose collapsed on the inside causing it to work like a check valve.
