That is a good question. If you are getting good flow at rear bleed screw and the wheel cylinder piston moves, why aren't the shoes moving. Could be as you suggest the pins are to short, but if they are tight against the shoe slot and the piston cup then they are correct length.
So the another option do the wheels cylinders and master cylinders compliment each other ? Are they matched ?
I re read the 1st post and know this is a 78, but which model truck, Blazer, or Burb ? What size are the rear brakes and what has been changed, Master cyl ? wheel cylinders? Both ?
