Rear bumps stops
cegusman
3/4 ton status
Houston/Katy, Tx
What is everyone running for rear bump stops. Especially those who are running 56" springs with a shackle flip.
Also anyone running air bumps in the rear. How do you have them installed?
I'm running cut down 4.5" energy suspension bumps with rectangle tube spacers for now. 56" springs.
I have a pair of s10 bumpstops that I will be using, I hear they are pretty soft so they should kinda act like airbumps. There is a thread about them on pirate 4x4
Well i ended up just getting these for my fox shocks.
Will run them and see if I need to go to a real frame mounted bumpstop. Really would like to do air bumps but not sure how to mount them when running leaf springs.
I run air bumps on all 4 corners. Never broke anything in the suspension and never feel a hard hit.
yes the picture is real.
unfortunately, that is mucho expensiveo
The poly ones would break apart with one hit and the best rubber ones I could find were too harsh. Nitro bumps are money well spent. I did this jump about 6 times and the landing was so smooth I couldnt tell if I was actually catching air.
rear s10 bump stop, and yes they are soft. My 2001 is the same
if you need to jump grand canyons from time to time, the air ones seem well recommended lol
