rear cv driveshaft
lunchbox
novato,california
ok, i was was getting real bad driveshaft vibrations so i shimmed the rear end 8 degrees im still getting bad vibrations when i decelerate. is it possible to have a rear cv drive shaft made that would work with my 208? or are their strength problems? i searched it and im still not sure.:dunno: oh and i dont wana drop the t-case.
HAD makes one:
http://www.highangledriveline.com/
__
sick! now this would fix the vibes right? the pinion and d-shaft are strait im gettin vibes from the dshaft to t-case
the key on a non CV shaft is to have both U-joints operating at the same angle. If you go CV you will need to rotate rear end so that the driveshaft is in a straight line to the pinion
This is one of the reasons you are getting vibes; both u-joints need to be at the same angle.
If you have a NON cv shaft, then that is why you have vibes. On a non cv shaft, both of the u joints have to be operating at the same angle. With a cv shaft then your pinion has to be pointed straight a the t-case. If you have a lift you may need a cv shaft though. since it gets noticeably worse when you slow down, it sounds like you have some axle wrap too.
If no CV needs to look like this:
If CV needs to look like this:
i just did this tuesday. cleared right up, now i just have all the other noises and vibes to pinpoint! theres no driveline vibes at all anymore. mine were really bad. i got one used and had to retube it and a new weld yoke on the end, iverall it cost me $260. new they wanted $500:eek1:
heres a good read:
http://coloradok5.com/forums/showthread.php?t=202539
im at school right now so ill take pics and post them up when i get home, for some reason i think ive screwed up my description, so i think pictures will help, sorry
I think we understand your description perfectly fine; Both angles are wrong.
To run u-joints at each end of a shaft they have to turn through the same angle. This means you need to lower your t-case and/or rotate your pinion down (smaller pinion angle shim) to match the t-case joint angle. You can't run one joint at 0-deg (your pinion) and one at some other angle w/o vibration.
Your pinion angle is set up rigtht now the way it should be for a CV shaft.
Check out the picture below:
Notoce how the angles at each joint are the same? If the working angle are both the same, but exceed more than about 5-deg, you will also get vibration. If this is the case then it's time to consider a CV shaft. I would first try and match you pinion and t-case angles before spending money on the CV setup.
______
