Rear disc/pic request
i used frt lines. then used front line brackets cut to hold just the line with the clip lioke a tab. welded them to the axle. and then just shortened the stock steel line on each side to fit. looked good. sorry no pics.
i got front lines, this is just a quick set up held on with zip ties till i have time to rebend lines and make brackets
I used front brake hoses for a 1979 Chevette, then made some angle brakets to hold the ends of the hoses to the axle tube, and then cut/flared the hardline to fit the axle.
X2 but I did not shorten my hard lines on the axel. Just bolted them up.
