Oops, I forgot the write up. I did the swap and everything went great. The only problem that I had was that the "pressure differential" switch inside the proportioning valve tripped. Meaning my brake light in the dash was stuck on and I had no way of bleeding the rear brakes. I took it to my local grease monkeys and let their bolt rounders power bleed the system.
After that, it stops perfect. I took it out and for approx 15 minutes I worked the brakes to properly bed them in. After they were set, I let them properly cool a bit then took it to a dirt field. I wasn't sure if the rear brakes were working properly so I knew if I took it to a field and stood on the brakes, the rear should lock up at some point.
Well, only after nailing the brakes about 7/8 of the way to the floor did the rears lock up in dirt and only for about 5 feet. So, unless I ever have to panic stop in the dirt while trying to avoid a dog 3 feet in front of me, I should be Ok.
But back to the swap. The only problem I ran into was that I destroyed 2 inner seals for the hubs. I just couldn't get the damn things to go in straight. The 3rd went in fine, so I was set. I replaced all bearings, races, and seals. This kit is VERY well put together. It uses the proper rotors so I did not need to trim any lugs. Everything pressed together just fine. The only problems I did have are that, 1) a few of the lugs are loose in the hubs and will be dealt with soon, But the lug bolts hold the studs in just fine, and 2) it doesn't seem like the studs were quite long enough to do an adequate job. The lugs are holding onto the studs by about, maybe, 6 threads.
Do I need longer studs for this? I also have pictures to show the problem I am having. This weekend I will post the pictures I promise.
But to answer your question Downlo, I had no major problems.
Did you get the system properly bled? I do not know if anything in the system is different on my 89 vs your 91. Are you 2wd or 4wd? What rear axle?
Hopefully someone else on here will have more insight.
