OK...I was borderline on the rear end sag that Ryoken pointed out...until I went and filled it up with 30 gallons...now I am certain I have rear end sag...what do I do to remedy this? New leaf springs? New shocks?
1" zero rate...look at DIY4X or ORD. Inexpensive, effective, the ride quality doesn't change and it's pretty easy to do yourself.
Rene
Who sells oem replacement leaf springs?
Rears are 2.5", stock fronts are 3" wide
Rears are 2.5", stock fronts are 3" wide, aftermarket fronts are 2.5" wide.
Rene
good hd replacements but ride good. i have used this spring setup before in 1/2 ton
http://stengelbros.3dcartstores.com/22-403_p_3163.html
and there web site also has ubolts and how to measure them.
look in the local yellow pages.
truck spring shop or big truck parts supply place.
then ask if thay can get triangle leaf springs. or possible other brands.
then use the 22-403 part # to have then match. its the std # system for leafs.
22 = chevy
403 = the description of the leaf pack.
pays to have worked at a spring shop for a year and understand a few things.
and dont bother getting leafs re arched = big waste of money.![]()
. thanksWhere are the pics of the sag in the rear?
I'll have to get it on a level surface and take pics from the side...the front end is higher than the rear
