Rear height brake proportioning valve
Eric M.
Oakland, CA
-Rear height brake proportioning valve. On 81 to about 87, 1 tons had height sensitive rear brake proportioning valves. The adjustable valve was mounted to the 14 Bolt dif. and an arm went up to the frame. As the truck was loaded, the arm goes down operating the valve to allow more fluid to the rear brakes. I need all of the pieces.
Thanks,
Eric M.
[email protected]
Re: Big list of things I need
I think I have a wheel line up. I'm waiting for it to show up and if it all looks good, I'll remove it from the list ... if it doesn't, I'll let you know.
Thanks,
Eric M.
/forums/images/graemlins/k5.gifi have a dash piece if it is the same as 85 k5 it is in all right shap it isnt cut open for a full faced radio the old style knob type i might have the plastic piece you are looking for and maybe the door lock pin if you can tell me what it is i have a 88 parts k5 that i can rob parts off
I've got a hood latch cable from an 86. It worked before I removed the hood 1 year ago. $5 Also got a rear window (non-slider), but I doubt you'd want it shipped across the country. $45 I guess is a good price?
I have a steering stableizer, and shocks all 5 for $30 plus shipping. If you want more details, let me know
I think I'm set with the dash, one is on the way, so unless UPS drives over it or something, I should be alright. Sorry for lack of description on the other stuff, let me do a little better. The door pins (I guess that's what they are called) are the things you pull up and push down to lock / unlock the doors. The plastic piece under the steering column is an extension of the dash which wraps under the bottom of the steering coulmn. It is held in with 4 screws, is about 10" x 4" with a curve at the top for the column.
Thanks,
I appreciate the help,
Eric M.
I'll take that hood cable as long as there are no cuts or breaks in the plastic sheathing (That's what mine looks like now). As for the window, I'm suppose to have a slider lined up but I haven't heard back from the fellow in a week. I think someone else offered one too, so I think I might follow up on that before trying a solid glass window ... but I may be back to you if everything else falls through. Let me know about the latch and if it looks good, e-mail me with payment / shipping price. I can do Paypal or money order.
Thanks, I appriciate it ... I know you won't retire on the profits from this, but I won't go broke at the dealer either!
Eric M.
[email protected]
/forums/images/graemlins/k5.gifI SHOULD HAVE THE PIECE UNDER THE DASH TO /forums/images/graemlins/k5.gif
if you get a chance can ya update what you dont have on its way. this way i can find it a lot easier.
thanks
Grant
LOL! I knew someone was going to say something about that soon. I have paid for a dash bezel and rim, and a friend is shipping the leaf springs - they are all on the way. As for the other things, I've got lots of posts and I've replied with interest to all of them, but no one has said "Send me this much $$ and I'll ship it to you" Let me know what you've got and if we can work something, I'll get a check in the mail the next day and it's a done deal. But so far only the dash bezel, wheel and springs are filled. I thought I'd wait till they actually show up and them delete them - they weren't hot items anyways.
Thanks again,
Eric M.
k, i got the under steering wheel panel. 5 bux. ill keep a running tab as to what and how much. once i get as much of the list done ill let ya know.
grant
