Rear leafs
rugged71
Registered Member
Arizona
I messed up and put the rear leaf springs in backwards, I think. The factory clips are at the rear of the truck. Is it backwards and will it mess anything up?
It sure will,if the center bolts are not in the exact center of the springs!..most aren't,and your rear axle will be moved forwards or back more,depending on their offset..
Unless you have a shackle filp it would be hard to put them in backwards. Because the spring eye is on the top on the front of the spring and on the bottom on the back eyelet.
