@TJ1978 if it's just a few drops, I doubt you will need to add oil often, maybe never between oil changes.
Sealing a gen 1 SBC is always difficult. The tin needs to be straight, intake angles change, when machined.
The rear main is an obsolete design, that is weak at best.
You are on the right track, start looking up high and work your way down. If your valve covers look wet that is probably it. I never used to use silicone with a gasket. 1 or the other never both. In recent years I use a super thin coat of silicone on both sides of valve cover gaskets. Makes them a bitch to remove if needed, but no leaks.
1 of benefits of higher emissions standards on modern cars, was oil leak were eliminated.
