Rear output for NP205
The rear output will be 32 spline, the front is the one that can vary.
205 rear only 32 or bigger with aftermarket .
front was old orignal 10 spline / then 30 spline gm and last was 32 spline ford and divorced case's
Then looks like I need a driveshaft to get some flange measurements from. Waiting on an eBay seller to message me back. I don't know if they measure from u-joint to the u-joint on the main shaft, or to the end of the flange
Got my super duty shaft today. It'll take the flange with a 2" pilot and bolt holes are 3" apart. For my application, it'll have to be shortened about 6"... I'll probably order up a flange today, then go to my local driveshaft shop and ask how/where they want me to measure for them to shorten it.
Here is how Denny's drive shaft measures.
  • Driveshaft.pdf
