rear springs what ones are the flexiest?
highrider_44s
southern B.C.
I was wandering what rear springs (ether stock springs or aftermarket) others have used to lift there rig and of course the flex results /forums/images/graemlins/deal.gif /forums/images/graemlins/woot.gifright now i have the stock 52" in the back with blocks want to get rid of the blocks and add some twist /forums/images/graemlins/laugh.gif thanks
Shackle flip is the cheapest and easiest and add some long travel shocks /forums/images/graemlins/thumb.gif. I have a through the hanger flip on mine with 13" travel shock, got crazy flex for stock springs and no blocks. /forums/images/graemlins/peace.gif
[ QUOTE ]
[/ QUOTE ]
Yea i got the shackle flip already forgot to mention that what i got is not bad just trying to upgrade and loose some of the block. /forums/images/graemlins/thumb.gif
is everyone running stalk springs /forums/images/graemlins/dunno.gif
is there a difference in the flex for a 52 to 56 springs. /forums/images/graemlins/peace.gif
wow, those front springs you have, must flex, well not at all. Am I wrong on that assumption?
[ QUOTE ]
[/ QUOTE ]
no way i took a couple of leafs out and they flex not to bad it's about 9" in the front with a 3" body lift and the 39.5 still beat the fenders when you flex and go through ruts /forums/images/graemlins/waytogo.gif want to run it on a ramp but don't know anyone around here that has one not sure the angles on how to build one i would post pics of my truck if i could figure out how?
As to the question if we're all running stock springs, no, we're not, but the majority here are running stock or longer springs but not necessarily arched for additional lift.
I am not sure if anyone here is running lift springs with a 'flip or not but I'm sure someone is.
[ QUOTE ]
[/ QUOTE ]
do longer springs give more flex /forums/images/graemlins/peace.gif
often. Can't say, always, cause well nothing is that simple. common longer springs around here are 57" ford springs and 63" Chevy springs.
Stalk..... /forums/images/graemlins/thinking.gif /forums/images/graemlins/histerical.gif I swear I am not try to be a jack arse...
I'm installing 63's on my blazer project that I'm building. /forums/images/graemlins/cool.gif /forums/images/graemlins/cool.gif
Hey Dan, how tall are your blocks? If they are 4 inches then you can simply remove them and replace them with a 4" BDS or TC lift spring. Or if you'd rather use junkyard springs figure out which spring (I think its the 63's) that give you about 4" and replace em with that. I know there are a few guys on here that run all spring lifts that are pretty pleased by the results.
The rear 4" lift springs still give good flex, most people just use the shackle flip because of the extra droop that it provides that a lift spring can't touch. You already have that problem solved....
But I still think you should drop it down a few inches and just hack the [darn] outta your fenders /forums/images/graemlins/deal.gif
don't care if she drops a bit probable going to cut the fenders anyway. got to see your fender trimming jobie /forums/images/graemlins/peace.gif
i'm not sure.the rear is where i get the majority of flex i did away with the overload leaf and added some shorter leafs.don't know how to show pics yet. they wrote that i ramped a 1200 at ttc on the video, it wasn't that good.if i were guessing i'd say17+ inches.
Do you run any type of an anti-wrap system? And how much lift do you suppose you got out of the springs? Was it bolt up and go or did you have any mods you had to make?
Sorry for all the questions but I saw your rig in action and I was quite impressed. I'd like to learn how you threw it together. /forums/images/graemlins/waytogo.gif
