Rear u joint rear shaft 14bolt
Search for conversion u-joint, you need s44/1350. Search “1350 conversion u-joint”
It is probably not a conversion joint, GM is too cheap to use those
it is probably a standard 1350 joint
It's a custom D/s it has 6 inch suspension lift 2 inch body lift, but I'm going to try 1350 see what happens
Well that does probably change things, didn’t see that in the original post
carry on
carry on
Well he said 86 k5 and 14bff so most people put a conversion joint instead of changing the driveshafts
The guy before me got it from a guy who died ,and he owned a junkyard so this thing is such a collection of many different years,
It's been a pain, engine is 77 454, heads are off 69 427 truck, dash is 88 k5 ,front clip and wiring 91 gmc, rear end 85 military 3/4 ton, motor mounts out 81 g30 with 6.2., and that's just the things I know about lol
That's how my dad's bronco was when we got it. Parts from all over the place. When it went back together, it was all 1977 parts so that way I didn't have to keep a catalog of what is what.
