Rebuild carb or buy completed
77ck5
Arizona, CA
So are rebuilt carbs nowadays any good or should I try to do it myself? I’ve only done little Mikuni carbs on my 2stroke bikes so leery of doing this myself. Got truck to run by priming carb no problem until I replaced tank and sending unit. Now that steady supply of fuel to carb it is leaking everywhere when I try it but it will not start. Assuming floats sticking but who knows it’s so old but won’t run, disconnected fuel line today again and primed and it started up. So I Was going to stick with stock setup until I figure out what I am actually doing with vehicle and get the carb done , any thoughts?
What carb are you rebuilding? When I did my quadrajet back in the day I was reading some hot rodding books and it made a big difference. A vacuum gauge and reading the spark plugs made a world of a difference along with timing.
It’s a Quadrajet and has 7045583 stamped on side of it if that helps. Quite a few various people rebuild them just not sure what route to go at this point
When I rebuilt my 78 qjet I had never built any carb.
If you just want a stock rebuild it's a cake walk.
Just follow instructions that come with the rebuild kit.
I did 3 after that one from a 73 to a 74 then a 77
If you want to know more I might have a book.
I would not mind something like that. Have to look at getting some literature on it. Gonna dig around more. Would be nice to have it capable of moving on its own for now when needed. Any rebuild parts dealers folks would recommend?
