I would like to, but My welding skills are not good enough to trust sealing fluid.Why not add a drain plug?
I would recommend Jakes Performance Transmissions. He has a bunch of videos on his web site and YouTube going into detail about known weaknesses of the 4L80E so you know he is fixing those on his transmissions. If you go to the big companies like B&M or TCI they will tell you all day how great their transmissions are, but give no details at all about what they did to them. There is a whole community of 4L80E freaks on YouTube that do nothing but build 4L80E transmissions, and everyone of them mention Jake's Performance Transmission at one time or another because they do business with him, and they know he is the Guru of 4L80E transmissions.This thread has simultaneously made me want to save up and go buy an overbuilt tranny with a warranty and also given me some modicum of confidence that it's not so much hard as it is complicated.
That's exactly what I do, I grind a couple of slots in a nut and weld it on the inside, then put a bolt with a copper washer on the outside.I did one on a 4L60E by drilling a hole and welding a castle nut to the inside of the pan (fluid can be drained lower by passing between the ears of the castle nut). I suppose you could cut a slot/notch in the front of any nut. Then a parts store standard drain plug with the rubber gasket in it seals it up. Most of these pans have obvious features showing where the drain plug is supposed to be, but of course you should verify clearance on the inside. Maybe somebody sells this as a kit?
I used a B&M drain plug on another that liked to leak and requires 2 wrenches to operate, so I wouldn't do that again.
I should push the converter all the way back, then add shims until I have 1/8 inch clearance? Sound correct?Push it all the way back into the trans, and measure the clearance, then shim it so it has 1/16 - 3/16" of clearance. So if it has 1/4" clearance all the way back, I would add 1/16 - 1/8", so basically some washers that are about .100" or so. I also measure the washers and make sure they are all within' .001 or so on thickness. Some washers vary way too much but you can usually find 3 that are close.
