It's hard to know. They've been moving things off-shore for a long time. I don't think there's one brand that has high quality across the whole line anymore.Is MOOG still the brand to beat regarding steering components for the drag links?
It was an used one I bought off CL after my tilt column disintegrated, presumably from being used as a grab bar to get in the truck.. so I’m not 100% sure, but it is the 1” 48 spline, I think maybe a 76ish..
Heat up that shaft with a small MAP torch and it will start to slide.Ok well i ran into an issue.. there is not any kind of retaining pins to melt or drill out and it’s about 1.5” short.. it is necked down on the end of the outter shaft, I was considering try to grind or cut that off but I’m not 100% sure there’s enough inner shaft to gain the 1.5”.. maybe I need to return this and buy one that has pins?
I heated it for a solid 2+ minutes, the grease it came pre-lubed with was boiling from the seam between the shafts and nothing, when I yanked on it, it felt like hard stop, as if the inner shaft was maybe flared out or something.. I read reviews from a different manufacturer with identical pictures and a guy said he had to beat it out with a hammer and then file/sand down the inner shaft.. I just bought another one with pins..Heat up that shaft with a small MAP torch and it will start to slide.
How come no one seems to make a 1” 48 spline female to 3/4” dd male adaptor? Then anyone with a splined steering shaft could use an xj shaft..We sell all the borgeson stuff as a mix and match if want to go that route. It's not cheap but it is good and it's what I refer to as a straight line solution, meaning you don't have any open ended stuff to figure out.
Not enough demand.How come no one seems to make a 1” 48 spline female to 3/4” dd male adaptor? Then anyone with a splined steering shaft could use an xj shaft..
