To find a vacuum leak spray something flammable around the suspect area, when you spray an area with a leak the idle will go up.I’m a total noob rock working on cars I’m learning as I go. How would I check for vacuum leaks? and if I find them is it as simple as a new hose? Thanks for any info!
It could be a cracked hose, loose hose, loose throttle body or even a missing or cracked gasket at the base of the throttle body.
