chaosunbound
Registered Member
I had some issues with my th350 and it was loosing a lot of oil around the dipstick tube. well before i could fix it i ended up running low on fluid and by the time i got to the garage it would barely move. fixed the leak (i think) and filled it back up with oil and it wouldn't move at all but in reverse. i went threw all the gears and tried messing with the shifter but nothing. I ended up just poping it in reverse and parking it beside the garage.
my question is do think a rebuild kit from like summitracing would fix it or do you think i just completely toasted it beyond repair and i should look elsewhere.
