New parts!
Well I just stumbled over this thread from a little over a year ago. Figured I would give an update for everyone that helped me out. And its a pretty sweet update if I must say so myself
First off, motor has ran just fine ever since the rebuild. I also painted the car about a year ago.
As I mentioned before I had more plans for the motor once I could gather the parts. So allow me to introduce you to those parts...
Nothing like a big bore TPI intake/ls style throttle body/aluminum heads/big cam setup!
Specs/brands:
Heads are Edelbrock Performer RPM 64cc
Cam is a comp cam XFI 280 around .550 lift and 280 duration
Intake is from FFI (First Fuel Injection) basically a huge version of the stock intake. This thing is massive compared to the stock version.
Other updates I have done along the way include new 1 3/4" Dyno Don Headers with matching ypipe(that fits exactly as it should!), SLP Loudmouth II exhaust system for a 4th gen installed by a shop, had a pair of subframe connectors installed at the same time, new rubber, plenty of other small things that I could go on about that aren't as noticeable.
Just getting the new pushrods today that I ordered after I measured for the correct length with a checker. I will finish putting the motor back together this weekend. Cant wait to drive this thing after the cam break-in. Got the high zinc oil in and was very liberal with the break in lube.
Specs/brands:
