black rust
Recently I rebuilt the q-jet on my k5. At first, I couldn't get it to start without a little shot of starter fluid. That stopped working after a couple times. I pulled the carb and removed the air horn to make sure I didn't put it back together wrong. Everything seemed okay, so I put it back together and put it on the truck. Started up fine first time, and every other time I tried that day. Went to start it today, and it went back to not starting. If I add a little starting fluid or hit the accelerator pump enough times, it will almost run, then die. Any ideas on what I did wrong?
