reconditioning factory aluminum wheels
Cornfield creations
Jasper, Indiana
I have a set of machined aluminum wheels off of a 96 s-10 blazer. The ones with the small holes w/o the rivets like the older early 90's s-10's.
The clearcoat started peeling on the wheels and there is corrosion underneath. Is it possible to strip the clear off and clean them up? I have heard of using oven cleaner to get annodizing off of trim. Would that work? Or should we just look for a newer set? Thanks!
I doubt you can get anodizing off with oven cleaner. Sand blasting is about the only way to get rid of that. You can get them powdercoated.
oven cleaner
easy off does work to remove anodizing.
I used to do it all the time to bike parts I didnt like the color of.
It will leave a very dull finish
Sounds like yours is a plastic clear coat though not anodized and easy off wont work on that
you have to torch off the old coat and then chuck it up in the CNC and turn it down to get a new finish. then re-powdercoat it.
I've done a couple of set of IROC wheels that the clear coat was peeling and and starting to yellow. Both sets I used some really fine sand paper. I think I started with 1200 then went to 2000 grit. I know it was wet sanding sand paper...but I didn't use any water. Took forever (5 plus hours per wheel!), but they came out looking awesome. One set I went on to polish, the other I left as is. Both are still in great shape with just the raw alluminum. But both of these cars are stored inside, and I only drive them once a month (if that), and only in nice weather. IDK how well the alluminum would hold up out in the elements.
Thanks guys I'm gonna try some of your ideas. They can't look anyworse if something doesn't work out. yeah it seems like a plastic clearcoat. So if I took a torch to them it would melt it off, and then try wet sanding them?Or would the torch make a mess of them?
are they machine finish or polished? either way i would use stripper first. and the torch will leave torch marks on it lol. stripper is a little more user friendly.
