I think I've asked this question before but I can't find it via the search (and it wasn't answered):
I have a 465/205 (10 spline, factory) setup currently. I've broken one 465/205 adapter and I'd like to make one that is stronger than the factory one and also design one that allows me to clock the transfer case up for a flat belly.
I'm considering a 231/205 doubler as well which involves a round pattern 205.
Here's the question I really need answered:
Since I have the figure 8 pattern 205 (and said adapter has mounting feet that hang pretty low and clocking is more difficult) I'd like to switch to the round pattern. Can you drill/tap the round pattern into a figure 8 pattern 205? I've read that you can and that you can't (i.e. the holes would protrude into the cavity of the case and could have sealing issues).
If the only issue with redrilling the case is the sealing issue I'm sure I could fix that.
Thanks in advance fellas
