chrism101
Registered Member
what is the best gear to put in my 1979 k5 with a 12 bolt rear i have 36's and as far as i know it is stock gear just want to know what will be a gear to put in it on low budget
Gears are not something you want to cheap out on. Cheap gears make a lot of noise and are prone to failure.
Get a good set of gears and get them put in by a reputable shop! Don't cheap out or you'll spend more money in the long run by doing it twice.
on the four wheel drive shifter it has a 2 low a 2 high 4 low and a 4high in 2 low and 4 low it does real good it is like haveing it in 4 high on most trucks it also has plastic locking hubs what is a good hub to put on there and how hard is it to put in
What gears do you currently have? That is the very first question.
Martin
stock as far as i know i just got the truck about 4 days ago it has a 12 bolt rear
i dont know i know it boggs in 2 high in 2 low it does pertty good
