mtnman210
So I've looked a a bunch of different diagrams from different sites and cant' figure out which is the correct way to wire a rely. This is the curretn configuration I'm running right now on all my fans,lights,etc.. I found it on here.
For example I'll use my radiator fan. just for information I'm not running a temperature switch I have control of of the fan off a switch on the dash.
I'm using Hella's 30amp relays to windstar fans.
85: to ground block
86 through 30amp fuse into switch that has constant 12volt
87: to + side battery post
30: to fan motor
Now I have no idea if this is how it should be but the fans work and don't blow fuses. I'm just curious since I've seen suggestions on wiring relays many different ways.
85: to ground block
30: to fan motor
