That was the whole problem on previous threads. Its some weird thread. So you found some pipe thread that fit????Currank5 said:That works i guess. When i deleted mine from my Jimmy i just used some plugs i found at the home depot.
Thats what I was thinking, some disconnect between early years and later, later must be some middle eastern metric BS; excuse if I offend any camel jockeys.79k20350 said:Wrong answer boys...NPT ONLY works for early year AIR sytems that use 1/4" npt fittings.
Roadnotca came up with an awesome solution. The newer fittings are flare and are much bigger, not npt thread. I couldnt think of anything to work so i just left a lil pipe and hammered it flat![]()
roadnotca said:Thats what I was thinking, some disconnect between early years and later, later must be some middle eastern metric BS; excuse if I offend any camel jockeys.![]()
Salute 79k20350![]()
Signing off79k20350 said:I must salute you good sir, your the man with the plan![]()
