Removing C-clip axles (12-bolt w/ auburn)
Mastiff
Tucson, AZ
I had another thread but I want to get more eyes... I'm trying to pull my axles to replace the bearings and oil seals. I pulled the diff cover and found the little bolt that holds the center pin in place. It's just a little rounded already, must be from the shop that did this job for me last time. :mad:
So I'm trying to go easy here. Does anyone know what size head is on that little bolt? A 5/16 is the perfect size to totally round the thing out, just a little too big. but 9/32 won't fit. 8mm is too big and 7mm too small. I'm stumped. If I knew it was not too tight I could fall back on vice grips or something, but I don't. It could be tight. Any suggestions?
Also, is it okay to rotate the ring gear once the pin is out? I thought there was some mistake that could be done during this job that would screw things up, but I can't remember what it was.
Well, I went and bought a 5/16" six point socket in 1/4" drive with an extension. It grabbed. 12-point stuff should be illegal. I'm really hesitant to reuse this pin though. Can anyone tell me where I could get a replacement? Or do people just buy a grade-8 bolt and grind off the threads?
attachment.php
It's right. I can't believe it, but they had one at Checker. I'm in the clear. :D
glad you found what you needed.you never know what your local parts place has.its probably just a stock replacment.which for your needs is probably perfect.if the cross pin is worn you can get a replacement from the gear guys also that is hardened and wont wear as fast.but if it looks good,you should be fine with just a new crossbolt.;)
