buckmtn
I've got a bad wheel bearing in my front 3/4 ton 10 bolt. Took the hub cap off and the inner axle snap ring. Looks like it has a retaining nut on the outside that you have to take of but my wheel bearing socket won't fit it. Tried the hammer and screwdriver method but it didn't budge. Is this a nut or am I missing something. I don't see any other retainig ring to remove like some of the other articles talk about. Thanks.
Just a real pain in the a** to get that outer ring out. Is there just suppose to be one snap ring on the axle shaft itself? That is all I had but looked like two grooves on the end of the axle shaft. Thanks for helping out a newb.
on the side of the nut.
