My '78 c30 cab & chassis truck had a flatbed on it that used wooden spacers between it and the frame. When I pulled the flatbed off to put on a regular bed, I found some pretty bad rust. The rust is on the top of the framerail, in every spot that wood was sitting on it. The problem varies from being thinner than it should be, to seeing daylight through it.
Would it be better to weld on steel to plate over the rusted areas, or cut them out and weld in replacement pieces?
Here are some pictures-
..So I decided putting another tranny in it after it lost reverse was a waste of effort,and lit my torch..
..I'd hate to be hauling a heavy load of junk and have it give way on the road!..
