So I'm putting in a new fuel pump, and then decided might as well install a new tank. Everything looks good but figured maybe I should at least replace the 3 hard, fuel lines from tank to at least the fuel filter location...maybe even further.
Can't seem to find a source for them though.
LMC says carb lines only?!?
89' K5 Blazer
Also, there is a "canister purge valve" right at the tank. Is this stock?? I combed the junkyard and saw an 89' suburban, but didn't see this purge valve.
89' K5 Blazer
