k5ryder
I replace my U-joints this weekend and after taking it for a test drive I now have a bad vibration at 25MPH and climbing. The vibration is only when I have my foot on the gas. It stops when I left off the accelerator. I felt the vibration from 25MPH all the way to 35MPH. I have not tried to drive any faster. I replace the u-joints with Spicer 5-3147X. I tried installing the new u joints the same way the old ones were. I did hit the yoke with a hammer and I also used the vice to help press the caps in. Could I have knocked the drive shaft out of balance hitting it with a hammer? I also replaced my transfer case fluid this weekend and a new seal on the output shaft housing. I also put some grease inside the slip yoke before reinstalling it. I also replaced the shocks this weekend. FYI my blazer is a 85 that is completely stock with a 208 transfer case. I have included some pictures of my pinion angles. Any suggestions would be appreciated.
