Stomis
Professional Amateur
Should I flip the yoke?
Dont bother. You dont really know if the yoke is flipped or not to begin with. If it still doesnt feel right after you fix the needle then flip the yoke. It only takes 5 mins.
did you wack the yoke ends were the caps are to free up the tension like I said ?
were the caps sit in the drive shaft yoke .
smack the base of the yoke just before the tube weld .
do this for each side and each u-joint .
this will relave stress from installing u-joints.
flex the joint before and after you will feel a difference.
Did you take the rear u-joint apart?
