Replaced intake, now engine won't start.
ciffer
Southeast MN
I installed an edelbrock TBI performer manifold, now the engine won't start.The engine turns over and is getting fuel to the intake. The engine will pop sometimes but it isn't regular. the popping changes frequency depending on how the distributor is situated.I checked the plug wire routing twice. I also replaced the cap and rotor. when I had the distibutor out.
I'm going to say the distributor is out as well, with as many times a I have had a dizzy out and back in, I still ocassionally get them back in wrong, not sure how it happens when I go through the same procedure as always, but it happens. :doah:
The procedure has been beat to death, but there are new folks coming along everyday. Somebody needs to write up a detailed procedure and post it as a sticky.
Anyway, short version: Take the cap off, pull the no. 1 sparkplug.
Put your finger over the sparkplug hole, bump the engine around while watching the timing marks on the crank if you can.
If not, don't worry about it for the first time.
When the compression blows your finger off the hole, stop and look at the dist. rotor.
It should be pointing somewhere close to the No. 1 position.
If its pointing exactly opposite, then your dist. is 180 degrees out and will have to be pulled.
At this point, look at the timing mark, and if its at 0 degrees (TDC), then you are in good shape.
Odds are, its going to be past it.
Carefully bump the engine around again until the TDC mark comes up the second time.
In other words, bump it past once, and stop it on the mark on the second trip.
The rotor should be really close to where it was when the pressure stroke hit on the spark plug hole.
With the timing pointer at 0 degrees, pull the dist. and spin the shaft around until its pointing at the no. 1 mark and reinstall.
Remember, the crank goes around twice for every one revolution of the dist.
tryed turning the distributor 180 degrees, didn't work. Finally just pulled the valve cover and turned the engine by hand until cyl #1 was at TDC on power stroke, pulled the cap, the rotor was about 90 degrees from where it should be. I pulled the distro again and turned the oil pump until it lined up correctly. I put most of it back together, I'll try to fire it after work tonight.
thought I had it, turns out it was at TDC before power stroke, turns out it was at TDC before intake stroke. flipped the distributor again and it fired right up and ran it long enough to time it. needs a themostat gasket and a hose clamp, other that than that i think it is set.
All right!
Like they say, its been a long strange trip, but looks like you got it on the run.
I doubt that you are unique, but most folks either wind up with the dist. one tooth out, or out by 180 degrees.
Its kinda unusual to get one out by 90........
But that does explain the adjustments you had to do to get it to run.
Did you figure out the noise yet?
I'm betting on the alt. now since the starter did not explode when you got it going.
