The tool should have a place to put a wrench to hold the crank from turning. You hold the wrench and tighten the nut against the pulley. It is done just like the tool for the pulley on the power steering pump.
That’s incorrect. Pulley shoulder Keys into balancer, then all the bolts go in. Main center and 3 perimeter.bolt and washer get torqued on first, then the pulleys get bolted with the 3 bolts.
Pulley shoulder Keys into balancer, then all the bolts go in. Main center and 3 perimeter. I would run the pulley you had because you know it works, but a small bump in a/c and p/s rpm might be a good thing??Does the crankshaft bolt go in before the pulley, because the is a "lip" around the pulley center hole that would prevent it seating properly if the big washer is already on with crankshaft bolt.
Also, if I use the new pulleys I bought the AC and power steering belt sizes will change and they will spin faster than before.
