user
Registered Member
yes. when you put the bearings and race into the cup and roll it around, it'll feel gritty-to-rumbly in your hand if it's bad. it'll feel silky-smooth when you rotate it if it's good.
user said:yes. when you put the bearings and race into the cup and roll it around, it'll feel gritty-to-rumbly in your hand if it's bad. it'll feel silky-smooth when you rotate it if it's good.
user said:You're right about what the service manual says, but that's written for dolts, some of whom work as mechanics at GM dealerships, and assumes that each step needs to be spelled out as if building an entirely new differential from parts. The tech writers had no way of knowing which parts you might want to replace, after all. If you're not replacing the side bearings and shims, all you need to do is put that stuff back together exactly as it was.
daleearnhardt01 said:While you are def correct about the morons who work at dealerships etc, I personally just like to be sure everything is to spec after doing something like pinion bearings, etc. Its not like it takes a lot of time to check preload or something. Better safe than sorry IMHO.![]()
http://www.littlemachineshop.com/
user said:Here's links to some pictures of a tool I made for
holding the flange while removing the pinion nut.
It consists of a piece of 1" angle iron with two
holes drilled in one end using the U-joint flange
strap as a template. It's important to drill the
holes in such a way as to avoid covering up the
nut with part of the tool. After installation
of the tool, I used a 18" long 3/4" drive breaker
bar to loosen the pinion nut, and whizzed it off
with an air-impact wrench.
http://virginialegaldefense.com/INFO/DSC00922.JPG
http://virginialegaldefense.com/INFO/DSC00924.JPG
http://virginialegaldefense.com/INFO/DSC00925.JPG
http://virginialegaldefense.com/INFO/DSC00926.JPG
jonrpick said:Excellent... My breaker bar is probably right at 18", 1/2" drive, and yesterday I ran to Sears to get a Craftsman 1.25" socket to fit it. Sounds like I'm using a similar setup. Hopefully the angle-iron brace will do it.
I don't have any air tools at the moment, nor a compressor, but if I need to I can borrow some from a friend next week.
On a side note, I pretty much destroyed the rear u-joint trying to get the driveshaft separated from the yoke. It was stuck on there pretty good. It took some prying from different angles, and finally one end of the joint let go and shot it's cap and roller needles across the floor
Thanks for the tip!
user said:Put the breaker bar on the right hand side of the nut (left or driver's side of the truck) angled slightly downward, say at four to five o'clock. then roll your floor jack up underneath of the end of it and start jacking. Use the weight of the truck to get the thing loose. That's why I use blue loctite on these things rather than red! Make sure when you do this that the breaker bar is at 90 degrees, or else the jack will just make the bar swing inwards rather than up. If you want to add leverage, use a piece of galvanized steel pipe (not iron gas pipe, 'cause it'll bend too easily) the inside diameter of which is just larger than the largest outer dimension of your bar handle, maybe four to six feet long; slip it over the bar and jack up the end of THAT. More length equals more leverage equals more torque at the nut, which will acting as the fulcrum point of the leverage system. If that doesn't work, use an electric heat gun (not an arc, you'll fry the alternator; and not acetylene or mapp, too hot; and not even a propane torch, too much risk of catching stuff on fire) on the nut and try again, but be careful not to ignite the oil, grease, and gasoline that's in that area, and recognize that you'll be trashing the oil seal and possibly the bearings. Of course if you catch some of those flammables alight while you're under the truck with limited crawl space, you'll be re-creating the napalm experience of Viet Nam, right? It'll be a horrible death. You want to get the nut hot enough to do the thermal expansion thing, and possibly to melt the loctite a bit, but it doesn't need to start glowing, right?
user said:I've been thinking some more about the original mission, which was to replace pinion bearings, in connection with the too-hard-to-get-off pinion shaft retainer nut. The fact that the nut is on there so tight explains why the bearings went bad. It takes a lot of torque (300 to 400 foot pounds) to get the nut into the proper position, because the crush sleeve has to be compressed. But you have to do that very carefully, because it should take between one and two foot pounds of torque to overcome the friction necessary to make the pinion shaft move with bearings and nut installed, because of the preload the crush sleeve is imparting to the bearings. So your "real" problem is that some idiot overtightened the pinion nut.
I use a four-foot length of one-inch galvanized steel pipe as a torque multiplier; I slip the breaker bar (a Craftsman 3/4 inch drive, 18 inch long model) into the end of the pipe, which fits perfectly. The frame of the truck has to be about 20 inches off the ground in order to do this properly, but I turn that pinion nut about one-sixth of a turn from each side of the truck (I'm using a six-point socket - if it were twelve, I wouldn't have to move from one side of the truck to the other, but I'd probably break the socket) until I get the requisite torque in turning the shaft. Here's the hard part, which lazy people who overtighten pinion nuts seem to want to skip: you have to remove your flange-holding tool after every couple of tightening moves with the breaker bar after you've got it down tight, until you (1) can feel that there's no play in the bearings, and (2) get the bearings tight enough to give the necessary preload. That means, tighten the nut a little, remove the flange retainer, check the shaft, replace the flange retainer, tighten a little, ... - repeating as necessary. It's a time-consuming process, but self-discipline and patience will pay off.
AS to the use of the special flange retainer tool I made out of a piece of angle iron: When you're removing the pinion nut, you want that piece of iron to stick out from under the truck ABOVE the leaf spring on the passenger side, so that turning the pinion compresses the iron against the spring - that's what keeps the flange from turning. But when you're installing the pinion nut, you want the angle iron to stick out from BELOW the leaf spring so that twisting the shaft clockwise compresses the angle iron upwards against the spring. I use a bungee cord to hold the iron tightly to the spring while I'm turning the pinion nut. So it's really the leaf spring that's holding the flange in place while you're turning the pinion nut.
Another btw: the crush sleeve acts as a compression spring, so, at least in theory (I don't go to this much trouble if all I'm doing is replacing an oil seal), you're supposed to use a new crush sleeve and pinion retainer nut every time you loosen or remove the pinion nut, because that decompresses the crush sleeve and it can never be compressed exactly that way again.
Also, when you put the flange back on, be sure to stick some Permatex Ultra-Black oil resistant non-hardening sealer on the splines of the pinion shaft down onto the smooth part and into the recess of the oil seal, but not so much as to get it into the bearing. My 1990 shop manual refers to a Permatex non-hardening sealer product that is no longer made, but the black silicone stuff works better, in my opinion. And don't shove the oil seal too far in - it's got to be flush with the surface of the top of the hole in the third member that the shaft sticks out of. The seal doesn't seal the shaft, it seals the flange.
Ok, now I think I've said everything I know about differentials, so like Forrest Gump, "that's all I've got to say about that."
bear76 said:Or just spend the $50.00 and get another rear off craiglist or JY.
